150hp ficht my2000, loose cable?
Ollepira
I have a loose cable which i cant find a home for. It runs from the emm and is red and black. In the parts manual it is worded " fusable link kit, Aux battery". Anyone got an idea where this should go?
Best regards Kalle
woody66912
Re: 150hp ficht my2000, loose cable?
It will bolt on the bottom of the power distribution panel. look for the 1/4-20 bolt hole, the bolt hole threads are brass.
Ollepira
That sems to be a blind connection to a brass connector moulded to the fusebox. What purpose have this cable? The engine run well without it. I noticed it was loose and got curious.
Regards Kalle
boobie
It's a connection for an auxiliary battery when you have one in the boat to charge it.
woody66912
It's a connection for an auxiliery battery when you have one in the boat to charge it.[/QUOTE
Thanks, boobie guess I should have explained that the connection takes place internally in the PDP.
boobie
My wiring diagram shows it's an external connection that you can wire to the aux battery.
Ollepira
Thanks, that explains why it run well wihout it attached.
