150 xp
jonesg
Re: 150 xp
Theres an leg interchange list at the top of this forum, probably in the top secret sticky file.
Its called top secret because no-one reads it, it may as well be classified. :)
stlouispondguy
Re: 150 xp
I have taken the time to read those files. But I still need to know can a evinrude 2.6 powerhead be bolted to the mid section of an 1983 evinrude 150xp? can any one answer?
emdsapmgr
Re: 150 xp
Won't fit. You can probably determine the correct parts matchup from the online factory parts lists. Check out the Bombardier website: epc.brp.com. FYI, the crossflow flatback 150 (early 175, early 200) engine is 149 cubic inches, the later 2.6, 235 and late 175 (bubble backs) are all 160 cubic inch engines. You will find all these big block engines are ported differrently than a 150.
