Wayne Nelson
Thread starter- Joined
- Apr 21, 2009
- 7
First let me say this is a great site and it is nice to see people donating their time to help others. O k here go's I own a 2001 150 HPDI VZ 150TLRZ THis winter I tryied to fix two poublems 1) my tach was not working it turned out to be a broken wire where the main harness enters the engine. My cousin is an electritian and he opened up the harness fixed the wire and a couple others seeled it back up and pushed the harness a couple of inches inside the engine and all seemed to work fine. 2) My oil light was on with no alarm it turned out to be the float sensor inside the oil tank in the boat. the sensor inside the toob move slightly upword (proubly due to high waves on lake Erie) when it was at the top of its range (it only had about a 1/2 inch range then it hit a "C" clip) the light would be on and off at the bottom. We simply removed the clip understanding that my light will come on when I am almost out of oil and turn off when I'm out.
Now this year my oil tank inside the motor will not fill on it's own, my alarm works when it is empty and the override switch works to manually fill it. So far we have tested the float and got continuity in three spots bottom, slightly up from there and at the top. So I feel that it is fine but do not know what to test next.
Thanks for your time
Wayne
Wayne
