carlosburitica
Thread starter- Joined
- Aug 12, 2010
- 24
so i have an evinrude 150 1994 ocean pro that i just got, when it got it it ran fine out the water, took it for a test drive and idled fine for couple miles, got out the inlet an at wot berelly got 25mph i figured old gas, cloged filter and carbs, cloged fuel vent.
got home a removed fuel and added fresh one, new fuel/water filer, plugs, cleaned carbs (quick cleaning before a rebuitd) checked fuel lines, installed a new primer solenoid old ona was leaking. i have no air in the fuel system. perfect and running out the water.
took it today in hte ramp and had a hard time to star it did, but for some reason i was feeling that i was not getting spark of was flooded. well removed sparks and starbord plugs were like new, and no spark on that side. so it runs but only 3 cylindes, the other just don't get spark, compression is even in all cyl.
what you guys think...powerpack went bad, or it is running on safe mode,...cutted 1/4" of spark p wires and reinstalled boots and nothing no spark at the starbord side...head gets hot but i am sure is from the friction caused by the pistons. test ligth no spark.
other side works perfect, plugs look brown from a good mix...my only guess electrical please help
