crazy charlie
- May 22, 2003
- 5,670
Hi guys,hope someone can point me in the right direction.1995 150 ocean pro is trying to engage in reverse ,the prop is turning a little and I can clearly hear the gears trying to engage but only actually engage once in a while when I push the reverse throttle down until the rpms are getting too high to safely engage.Fwd works fine and there were no metal shavings in the gear lube when I changed it.Is there a simple way to determine if it is an adjustment in the cable or something more serious??
