looking for help.I just bought a used boat that had a 150 johnson 6cylinder o/b that i took to a great mechanic to get a opinion on,was there held the gage myself and had 87 psi on all cylinders.The boat belonged to a elderly man that had passed and had been sitting up a couple years.I took it out and it ran great,had a good pee stream but ran a little hot at idle,cooled off good as i sped up.took it in to get a waterpump i thought, when i found the #6 cylinder had no compression and took the heads off and seems water got in it and pitted the piston and broke the rings etc.the other cylinders seem fine.the motor was rebuilt two years ago so the mech. is going to bore out the #6,replace waterpump and thermostats,clean carbs.,etc...Any ideas what could have caused this as the head gasket looked fine.I really don't want to rebuild if i don't know what caused it...
