150 Johnson V6 1984
basstracker
Pressure relief valve on left side of motor seeping water, changed both valves, springs ect.. but still leaking? Water pump seems OK no overheating? Any Ideas????
Dhadley
Re: 150 Johnson V6 1984
If it's leaking out of the small ho;e in the center of the cap make sure the diaphram is seated in the groove. Clean the groove and a dab of OMC gasket sealer won't hurt either. Also check the diaphram for cuts and / or holes.<br /><br />Good luck!
