150 hp force
terryb9073
was going across lake about 4500 rpm suddenly started missing badly. from start to about 3000 rpm runs perfectly go above that and seems like out of time...could be timing or collapsed gas line? i need help..........
jerryjerry05
Re: 150 hp force
Check the diaphram in the fuel pump.Then the filters.Check for water in the gas. You might be suffering from Ethanol poisoning.J
