150 gt shift linkage removal
old wise bison
Cant get the 150 shift linkage to loosen and come off of the holder clamp .Is the pin that goes thru the hole in the shaft spring loaded , Got the horazontal shaft out,but the (horseshoe type clamp that has a pin in it wont come loose from shifter shaft) 1987 gt manual shift. Do I need to pull carb to see whats holding this gizzmo to the shift shaft ? thanks.
