Force 150 '93 5 cyl<br />1)Is it normal for the carbs to leak with the engine tilted up? I noticed fuel pooling in the carb face plates.<br />2)The motor, up until recently used to start with the bump of the key without advancing the throttle or choking and even before choking or advancing throttle I smell strong Fuel. Now I have to do all that and most of the time it will not start, and when it does it smokes alot and runs for only a few seconds, seems like it dosent get spark on some of the attemps to start. I beleive maybe a short in the kill ground,ignition grounding out?Water in Fuel?<br />3) Also while running for 10 mins or so at 1/3 throttle,if i try to WOT it dosent do anything, only a very slight and almost unoticable increase in rpm or speed.<br />All of these problems beagan recently and at the same time.Please help Thanks in advance.On top of that at the same time My trim relay is bad and I beleive that now I have a pinhoLe in the fuel tank.
