Lil' Johnson
- Jul 13, 2008
- 36
Hey people, I have a 1985 Johnson 150 on my 19'4' deep vee center console. It has a 19 pitch prop. My problem is that my motor does not like to idle or even go slow at trolling speeds. It runs very well at cruise or WOT but if it idles for more than a few minutes, it will die and then it is a pain in the *** to get underway again. I can always get it started ok but when I put it in gear, it bogs and dies. When it does manage to get going it bogs pretty hard and then it catches and takes off. According to my tach(which I am not sure is accurate or not, but I think it is) the motor is idling at about 600 RPM. I have pulled the plugs right as I am having these problems and they are always pretty wet and black. I don't think I have ever pulled them and saw a nice tan color. (I am an auto mechanic by trade, but I am not sure what the plugs should look like with the oil mix in the fuel) I was thinking maybe raising the idle will help but I am not sure how to adjust it. I also thought maybe the idle mixture on the carbs was too fat but IDK where those adjustments are either. It looks like I adjust the idle on the throttle linkage. Any suggestions? I like to ask here before I go screwing with things that I should leave alone. Also my boat only shows to be turning about 5000 rpm and it used to show 5200. It goes about 42ish WOT. Is this an acceptable WOT RPM range? I am definitely happy with the boats performance other than the low speed issues. Motor has new stator, plugs, 1 power pack, and carbs have been cleaned checked and rechecked. any help guys?
