Bruskyfish
- Apr 29, 2012
- 2
I posted a couple weeks ago and have tested all suggestions ( spark, compression, ect )
And still the same lack of power issue. I was out messing with it today and realized a descent amount of oil build up under the carb, so I took the cover off and noticed a small puddle of gas on the bottom left carb intake. I started it up and that carb was a steady strong mist at idle and it seems to not change when throttle is raised. All others seem to be normal. This I think would explain why it idles better with motor trimmed up. What is causing this? And is there anything I can do to fix without taking apart carbs? Any help would be appreciated
