150/175 bore stroke?
Dhadley
Re: 150/175 bore stroke?
Yep, I remember all of them. Crossflow, big bore crossflow, 60* loopers - all of them. Which ones are you looking for?
sledmonster
Duh sorry,
I have a 83 crossflow with some confusing makings could be a 150 or 175 just wondering stroke?
Dhadley
The 150 and 175 crossflows in 83 were both 3.500" (std bore). Both used the same block, crank, rods & pistons.
sledmonster
Any idea how they had different horsepower?
Thanks
Dhadley
There are some carb differences but on most pleasure boats you'd be hard pressed to tell the difference. The NMMA has a 10% rule about advertised horsepower. If the 150 is a tad more and the 175 is a tad less.....
Or if the 175 is rated at a higher rpm.............
You get the picture.
Dhadley
In fact the 200 crossflow used the same block casting but the port timing was different. The 1978 & 79 235 (small bore) had the same crank, rods, pistons, gear ratio etc but used a "tuned exhaust", different heads and carbs. Remember, these were all powerhead rated motors. Even the big bore 235 in 1980 can't hold a candle to the 60* 150's that came out in 91.
