G
Guest
Guest
Hey all. I was in the bay and i hit something going slow. Good part is everything worked fine in the lu to still stay out for couple hours. When i was took the outboard out of the water(15 merc) i noticed a little gear oil leak from behind the prop. I opened the screws and drained the oil but did not look like water got in it as gear oil did not change color. When i pressure tested it, it was not holding pressure. I think i blew a seal prop shaft. My question is, is there anyway to get a cheaper bearing carrier tool then paying 60-80 dollars for one? Or should i just keep using my outboard and keep checking oil for water?
