Robert S. Davis
Thread starter- Joined
- Aug 13, 2009
- 6
77 Johnson 15 hp, 15E77M,
Engine starts and runs fine except! Starts out fine under load, shortly it begins to labor and hesitate, removed plugs, top is fine, lower plug has water accumulated in recess around electrode and some on tip. Clean the plug and it will water foul again in just moments. I'm getting water into the crankcase (from the water pump) indicating a gasket, hole in plate etc. Where should I start to find water intrusion point? What is the most likely culprit? Should I just disassemble and replace all gaskets? What area is the most likely to fail? As you can probably tell, I want to eliminate the easiest to repair first. Thanks for any help
