I have a mid 80s ,15 hp Johnson engine. Have recently replaced the thermostate after noticing poor water flow and engine heating up. Thermostate was seized. The gas I used this year was old and may be heavy mixure. My problem this year is hard to start. When the motor is running I can hear a popping sound(similair to pop corn popping) as I increase the speed and the engine dies as I put it on full throttle. Its like it isn't getting flow of gas. The motor will not stop and still pushes the boat along and doen's seem to be ovewrheating as there is a steady stream of water coming out the water pump exhaust hole. I pulled the plugs and there is a black oil on plug but nothing really bad. Any thoughts would be graetly appreciated. Guy down the road thought maybe a blown head gasket.
)[/QUOTE]
