15 hp Johnson late 90's
Kick31763
Got oil leak around prop housing and smells bad like gear oil anyone have idea what seal needs replacing
hardwater fisherman
If you have water in the gearcase and you need to change a seal then maybe just buy a seal kit. And replace all the seals. Have you checked to see what the gear oil looks like? You can get a complete seal kit right here for under 40 dollars.
