4chevys4me
Thread starter- Joined
- Aug 13, 2010
- 5
Thank you for all your help and patience. After lurking on this site and asking a few questions I have my motor running purrrrrfect. Got the motor for $ 0.00 and it had bad spark. Flywheel would not budge. I soaked it pulled it heated it and nothing. Finally after drilling about 50 holes in a circle around the shaft and removing the bulk of the flywheel, I was able to cut it off with my die grinder. Walla, Points and condensors. With some from help on this site I was able to get the correct parts, clean the carb. Now I have an almost new 1987 motor. Almost junked it, but stuck in there and I think it was worth it. Thank all of you that helped. I can safely say that I know this motor inside and out. The impeller change was a breeze. I hope I can help someone else in the future on this site. Bring on those 15hp questions.
THANK YOU
Paul P.
THANK YOU
Paul P.
