Hi,<br /><br />What year? Some years 75-77 or so they didn't have one. If there is a tell-tale, it is on the starboard (gearshift) side on the lower pan (the blue (?) part) near the rear. (sort of on the underside) It's a little plastic disk with a hole in it. You can see the water hose connecting to it with the cowling off.<br /><br />If you're new to that motor you should read this if you haven't already. <br /><br /> 15 hp article <br /><br />take care.<br /><br />Brent
I am not sure of the year, however here is the model number E15ECNC. I have read the article you gave me on the maintenance and am still confused of the where abouts of this hole. I would prefer a picture. <br /> Thanks
I appreciate the pic. I did start it up and did not notice any water coming out of it. Should there be a constant flow similar to the Johnsons that I have worked with in the past?
