15 HP 4 stroke evenrude year 2000 engine problem
Brycedriscoll
If someone can please help?
I have a 2000 4 stroke outboard evenrude. It was running fine Saturday it seemed. I have noticed lately that the water that is supposed to spit back out after cooling the motor isn't really coming out all that fast. Engine seemed to be choking alot thought maybe it was getting low on fuel. Not the case lots of pressure on the ball. New filer,new oil, new plugs, new gear oil every single year. This motor dues not have alot of hours on it as I got it from my Grampa. When I pulled the cowl off as the engine kept quitting at low rpm and left me out in the middle of a lake. I pulled the cord again and immediately noticed watery oil pissing out the intake. When I had a guy tow me back to shore I pulled the dipstick and saw water pouring out I new I had a big problem. Immediately went home and drained the water and oil right out of the engine. Possibly did a water jacket crack and water was going into the engine oil. Nothing happened that would allow water to get it any other way ? Expensive? Please help.
Silvertip
Honorary Supreme Mariner
Change the oil and filter and run the boat for at least a half hour at about half throttle. Then stop and check the oil. It may still be a bit milky from the previous episode. Change oil again if necessary. Then keep a close check on oil level and condition. If milky oil continues after several oil changes it is time to investigate deeper. Blown or leaking head gasket could be the cause.
