15 horse Johnson., no spark
Hugster
J15RLCNC no spark . Checked kill switch.ok output of coils from spark plug 275 ohm to gnd. Ohms across each coil almost shorted.How do you check stator output. Replaced cdi still no spark. Any clues. I evidently don't.
legalfee
No fire at all: 1. Disconnect the kill wire and retest. If the ignition now has fire, check the kill circuit. 2. Check resistance between the brown and brown/yellow wires. You should read approximately 450-600 ohms. DVA (peak voltage) should be 150v or more. 3. Check resistance between the black/white and the white/black trigger wires. You should read approximately 40 ohms. DVA (peak voltage) should be 0.5v or more. 4. Inspect the flywheel outer and trigger magnets to see if they are loose or broken. 5. Disconnect the rectifier and retest. If the fire returns, replace the rectifier. No fire on One Cylinder: 1. Swap the brown wire with the brown/yellow wire and see if the problem moves. If it does, the stator is likely bad. 2. Check the power pack and trigger. High speed miss or weak hole shot: 1. Connect a DVA meter between the brown and brown/yellow wires and do a running test. AT NO TIME SHOULD THE VOLTAGE EXCEED 400v. If it does, the regulator circuit in the power pack is bad. The voltage should show a smooth climb and stabilize, gradually falling off at high RPM (above 5000). If you see a sudden drop in voltage right before the miss becomes apparent, the problem is likely in the stator. 2. Disconnect the rectifier and retest. If the fire returns, replace the rectifier.
