140hp mercruiser outdrive to 165
liqhx2
I am looking at a solid boat that has a inline 6 mercruiser but a bad out drive. sterdrive serial # 3326483 engine serial # 3292231 on the 165. I have a rotted out 1979 glastron with a mercruiser 140 inline 4 in it and I cannot get the serial number off the outdrive or motor as they have been taken off. My question is will the outdrive on the 140hp work with the 165hp?
Re: 140hp mercruiser outdrive to 165
Ayuh,....
You probably won't be able to buy a prop Big enough to keep the rpms under control.....
liqhx2
Thanks Bond-O, is the gear ratio handled in the lower unit or the upper end? If it is the upper end then I can probably disassemble and make sure all parts are in good shape and use my good lower unit correct?
Ayuh,...
The Ratios change with the Uppers......
liqhx2
Thanks Again Bond-o here comes another project =p
bomar76
And if you dissasemble the drive any further than seperating the halvesthe cost of the special tools (and knowledge) to reassemble it will be more than a brand new SEI drive with a 3 year guarantee.
liqhx2
Well I picked up the boat and was running through everything and the oil in the drive came out clean and clear so I looked into the bellow and tried to move the gimble bearing and it is seized up! Does anyone have a step by step guide for replacing the gimble bearing? do I just pull those snap rings and yank it out?
jerryjerry05
Take the snap rings out and a three jaw puller/slidehammer will do the trick.Be careful when installing the new.Make sure grease holes line up.Jerry
liqhx2
Thanks for the link Haut, I picked up a gimbal bearing Sierra part number 18-2100 does that sound like the correct one for my boat? How do you tell if it has a trim sender in the gimbal or not?
Ayuh,..... They're All the same....
FlatBlack
Sorry to bump an old thread, just wondering how this all worked out.
We have a pre alpha 165 with a cracked lower unit housing. I found a reasonably priced 140 pre alpha outdrive unit locally, and was wondering if I could just bolt up the 140 lower to my 165 upper.
I notice you say the gears are in the upper and it sounds like this is what the OP did?
Thanks much.
Don S
Please don't bump old threads, if you have a question, start a new thread of your own and ask away.
