1978starcraft140alpha
Thread starter- Joined
- Jun 14, 2009
- 4
I have a 1978 Starcraft American that I just picked up a few weeks ago for a hot tub that had been laying around in my back yard. So I dont have much in this boat. The boat hadn't ran for 2 years before I got it, and the owner had just drained the water jackets and block from winterization when I first went to look at it. He had mentioned that it ran when he parked it, although he felt the carb would need rebuilt. So the first thing I did was rebuild the 2 barrel rochester, Transom bearing, u-joints, bellows and shifter cable, then replaced the coil, cap, and condenser. She fired right up and away we went to the lake =-) so I thought. The shifter control stopped working before I could get her to plain out. Babied it back to shore, took it home, rebuilt the controls, they are working great now. Went to take it back to the lake, so I stopped and put some fresh gas in it, now the gas that was in it was old, about 1/4 tank, I added STP gas treatment and filled it. Well I got it to the lake and I smelled a little gas, and the boat would start, but not run. Out on the water, it would WOT at about 1600 rpm, in or out of the water. On the water, every now and then, the engine would surge and run upto about 3200 rpm but then back down to 1600. So I trailered it and took it hom and tore the carb back off and tore it back down and clean as a whislte, it's not the carb, accelerator pump, everything is working well there, Now for compression, 97-97-97-100lbs just tested it cold and got those readings, I am stumped, I was hoping for no compression on two cylinders so I could just replace the head gasket and move on, but now I am stumped. Lastly Spark, I have it, I can time an engine, and this engine doesn't seem to be lacking in spark. This is my first boat, thus my first marine engine, I understand how the engine works, but am still at a loss. Maybe something in the manifold? Any help would be greatly appreciated.
