140 Mercruiser replacement years for bayliner 2000?
tnstreamy
Any input on the motor years that will work bolting up in this 2000 Bayliner Capri 17.5 with Alpha II, ?
Ayuh,..... Have ya got the take-out motor, Complete,..?? Are all the accessories Good,..??
Are ya swappin' Long Blocks, or Bobtail motors,..??
If yer swappin' Long Blocks, 'n usin' the old accessories, a 1990 to current production pretty much,...
Bobtail motors, 'bout anything that runs can be dropped in, 'n hooked up,....
tnstreamy
okayyyy bobtail motor? found a '89 140 in a fixer?
tilt works bro in law was told outdrive ok it's all there.
Ayuh,.... It should pretty much drop in, plug, 'n play,..... though there's Always a few "Gotchas",....
Do you still have the take-out motor,..??
tnstreamy
yep haven't started yet, bro in law just had triple by pass surgery this past Weds so project is a month or more out. just gathering info. thanks
Ayuh,...... That'll help in beatin' back the "Gotchas",....
Usin' the parts from Yer motor, And the replacement motor, it oughta be adaptable enough,...
tnstreamy
I guess it's more of a get it and see. he was concerned about electronics, motor mounts, linkage, gimble, outdrive to a earlier year motor like the bayliner 140 '89 I found..
Thanks Bondo
