140 looper sluggish at low rpm
JOFO17
I have an 87 140 looper that doesn't seem to run right. I took it to the local shop and they did a compression test and gave it a look over. They said I had some water in the fuel and when they ran it on their external tank it ran just fine in the test tank. When I took it out on the river it didn't run well. It kept stalling in low rpm reverse, and was very sluggish at low rpm forward. When I opened it up it seemed fine except for slow throttle response. The one thing that in my opinion points to a fuel problem is that I burned almost 3 gallons of fuel just making a few back and forth passes. Im talking less then 15 mins total run time. Time to get the carbs redone or do you think I may have a different problem????
boobie
The shop said you had water in the fuel. Did anybody correct that problem before you started running it ??
JOFO17
I was running on an external tank with fresh gas so wasn't a bad fuel issue.
boobie
Check your spark. It should jump a 7/16" open air gap. Then do the carbs.
JOFO17
Just an really delayed update, it turned out that the genius at the local shop didn't have the gaset that goes behind the intake manifold so he used permatex. A big thanks to my new mechanic for figuring it out. And a lesson learned by me. I put off goig to my new mechanic because he was one of the more expensive guys around. Obviously it was for a good reason! From now on I will pay the extra money and take it to him.
jimmbo
The Genius should have obtained the gasket, even if it meant you had to wait a couple of days. 3 gallons for 15 minutes isn't excessive for that engine
Faztbullet
That's a small bore looper and it a pig on fuel, has crappy carbs so forget a good idle, cooling system has to be top notch or bridged port will scuff pistons and lugging it will kill it so prop about 200 over max rpm.
JOFO17
It is surprisingly good in fuel after the leak behind the intake was fixed. Ran the C&D canal 13 miles against the tide at speed of 24 k and used only 8 gal. On the return trip with the tide pushing me ran 28k and burned 4 gals.
