johnsonjunk88
Thread starter- Joined
- Apr 24, 2008
- 23
NEED A LITTLE HELP ! Turned out the idle problem with this engine Jojnson -J140TLCUA bad orange wire going up into the power pack feeding starboard side coils . BUT while changing out power pack I broke anphenol conector pins the male ones cumming from under flywheel on the starboard side. The wires cumming from under flywheel are brown with white stripe and brown with black stripe. These dont match color coded wires on the new power pack the wires on the power pack are brown with yellow stripe and just solid brown. DOES ANYBODY know the correct way rewire the new male side anphenol connector? I cant find anything real clear in my manual .ANY INPUT from the PROS would be great THANK YOU
