140 johnson dies in the bay every time
Jimnoobie
Hi guys im new at boating. I got a 1978 glasstron with a 1979 140 johnson seahorse.
1st cold starts are a fight requires choking and cursing. (Unless on muffs in drveway she loves city hose water)
I have had her out in river and runs great 1000 rpm to 5500 planes quick. Problem i feel confident to take her to bay. Starts usal fight runs great 2 miles out in bay shut her down and drift . She never starts again untill home on muffs. This has happened 3 times. I can not figure it out. ? are the waves affecting my engine?
emdsapmgr
Weak ignition components tend to fail once the engine warms up to normal operating temps. Running the engine on plane opens up the thermostat pressure relief valves and keeps the engine cooler than normal. Once you shut it off, the cooling stops and the engine heats to slightly above normal temps. That's normal. It's also possible that the heat buildup is causing an ignition component(s) to fail. Probably not either power pack, as it would at least start and idle with one pack firing. Check the stator and timer base for cranking output voltages.
Jimnoobie
Compression test 116 -118 all 4 cylinders.
I teplaced timmer base a month ago due to no spark on cylinder 2 found out bad cdi replaced that too. I will check stator out tomorrow. Thanks for responses
ondarvr
What are your exact starting methods, both cold and on re-start?
oldboat1
You've been working on that motor -- sounds like quite a bit. Post the history.
Honorary Supreme Mariner
When you hold the choke switch on during cranking are the choke flappers completely closed ?----Have you adjusted choke solenoid for a little more tension on the flappers ?
Jimnoobie
Try to answer all questions butterflys snap shut appear to be closed visually same as manually.
Cold start: pump ball firm. Lever to start position. Choke and turn over. If it dont start in 10 sec. The cursing starts. Then attempt again while lowering throttle to about 25% usually will sputter at this point. A couple com on babies and another attempt or several , no exact science , not the same every time . Starts puff of smoke some times a cough or sneeze and stall . Warm up at about 2500 rpms untill thermostats open. Idles at about 800..at this point can turn off and starts right up in idle position ever time
Let sit for 20 min. May start right up or back or not
Jimnoobie
History : new head gaskets, carbs cleaned, carbs rebuilt, new plugs, ebay timmer base and cdi
emdsapmgr
When the engine won't re-start, have you checked each spark plug wire for spark. With a "gap" spark tester? That engine should have twin, identical power packs. You can swap them for ignition testing. (one controls the spark of one head.) Weak ignition components tend to fail once the engine heats up to normal operating temps.
