140 Hp Johnson Outboard
clarkdw26
I dont know a lot about small engines so here it is. My engine will start and run just fine most of the time. However after a few hours of running followed by a few hours of sittings my engine wont crank over. I replaced my spark plugs and found that they have a lot of fuel on them after the engine has been running then sits for a while. what can i do to fix this its not allowing the engine to crank over untill they are dry again.
kenmyfam
Re: 140 Hp Johnson Outboard
Carb needles leaking back ??? I have a similar issue with mine that will be getting attention this weekend. Do you troll for long periods of time with this motor ???
Post your model number and year so we know what we are all discussing please.
Welcome to iboats.
Bob_VT
Welcome to iboats.
Please define "engine won't crank" ? Do you mean the starter will not work or will not turn the engine?
