safetychain
Thread starter- Joined
- Nov 20, 2010
- 3
I have a 2003 140HP, 4-stroke that I have in the water in the Keys. For 5 years it has not had any problem. Last year it started running hot when it picks up any weed on the foot. Last year dealt with it by avoiding weed. Assumed that the water pump need replacing. Last week before putting in for the season, I replaced impeller. Had no effect. Any weed, and it runs hot. Thermostat works fine. Tell tale shows strong flow at idle and real strong and planing speeds. The slightest of weed and the tell tale flow falters and if I don't immediately back down and clear, will run hot and slow down. This appears to be likely an obstruction in the system somewhere. Is it possible to back-flush the system via the thermostat hole? Would I have to drop the foot also?
