140 h.p. compression???
captain bruce
please help!!! my first boat. has a chrysler 140 yr. is 78. 3 cylenders @ 145 & 1 cylinder is @ 125. what should i do??? thanks for any help!!!
Bifflefan
Re: 140 h.p. compression???
Welcome to iboats.
The first thing I would do is stop writing help, help, help... We all are here to both give and get advise. No need to beat a dead horse.
Your compression is not bad at all. If the motor has sat for a bit you can get a goofy reading, also it can be effected by how you do the test.
I would run the engine for a few days and see, then retest it. If its the same or still has a bit more cylinder difference that you like to see, try a de-carb (run sea-foam through it) and that may help.
Your best bet is not to over react.
Also you can read this link and this link from help.
captain bruce
o.k great advice...yes motor has set for abouy 2 yrs. had carbs off at time of compression check to rebuild. spun motor same# of revs on each cylinder. will check again now that carbs are done. THANKS alot.
