140 charger
Rhyno
I have a 140 chrysler that after it has been running the carbs drip fuel. There doesnt seem to be anything stopped up. The floats are not sticking. You guys got any ideas as to why it would be dumping to much fuel? Also it seems to use to much fuel running up and down the river. Any way to figure out why it uses so much. The pick up is not fast. It seems like it starts going after it is wide open and then starts picking up speed. Thought or ideas?? Thanks.
clanton
Re: 140 charger
Does the float hinge pin still have the helper spring? Check float needle, seat, and float level.
