Seattle Joe
Thread starter- Joined
- Aug 6, 2002
- 2
I was told my motors year to be 70' or 71'<br />1350/135hp/OB/Mercury/with ThunderBolt Egnition<br />with a red Cowl cover<br />Ive never found the serial# or ID Badge<br />or a positive year im looking for that info as well as ive got a cracked lower unit, and looking for prices. bare case vs. complete used. Any gasket Sets or rebuild kit.? (bearings/seals)?<br />Also do i need to find same year/horse power/gear ratio Lower unit case? or are they swapable with others?.. If So,<br />Do you know witch ones or any info on that please. Also prices for Shop manual and parts list.<br />(im sorry if you need to know the<br />shaft length, ive got pics on requests ill send.<br />it looks to be about 14"-16" from Prop Center -up to where it bolts to the rest of the tail..(correct?) My buddie says have it welded.. but someone told me, "bad place for the crack" starts at the prop output hole and travels horizonaly about 3"-4" then turns down for about<br />2"-3" Is it also true that, All the prop and output shaft is held in by a Inner Nut that has the threads on the outside, And threads into the case??? If so with the crack where it is, It could be possable to shift into Reverse and "Shooot" the prop, shaft,and gears right out the back!?? That dont sound right though a steel nut threading into Pop or cast Aluminumn???
