135 merc. OB jumps at no wake speed -1988
Penn State Pirate
New to this site today. Hello all.
I have a 135 Merc. outboard that runs great except when at no wake speeds. It jumps fast then slow. I am thinking it is the fuel filter which I have not checked yet. Any suggestions?
wtwe2step
Re: 135 merc. OB jumps at no wake speed -1988
Two things I would do...... clean carbs.....rebuild fuel pump
Chris1956
Honorary Supreme Mariner
That motor is a V6. It sounds like some cylinders are intermittently fouling at no wake speed, and then they fire. The cure is to adjust the idle mixture, leaning the affected cylinders somewhat, however, this only works if the carbs are clean. When was the last time they were cleaned?
j_martin
Some of them have a timing module on them called an idle stabilizer. If the idle speed gets too low, it advances the timing several degrees, speeding it up. If the idle is set close to the threshhold speed, it will tend to hunt for the right speed. (servo)
just a thought
John
Penn State Pirate
They have not been cleaned for a while. I do have the mixture a little rich.
