130 Johnson prop question
1997 cajun
Would switching from a 21 pitch Vipor to a 22 pitch Raker make much difference in performance?
Dhadley
Re: 130 Johnson prop question
Loaded question. The Raker will have more lift so if the set up is maxed out with both props, the Raker should be better. If the set up isn't maxed out for either, then all bets are off on both.
