12V vs 24V for trolling motor?
Lewis
Hi all,
I just bought a used trolling motor that has a switch allowing selection of 12V or 24V. Obviously, with just one battery, I'd use 12V. With 2 batteries, is there any advantage to series vs parallel?
Thanks,
Lewis
RicMic
Re: 12V vs 24V for trolling motor?
Well, I'm sure you know with two batteries, series will give you 24V and parallel with give you 12V. Going to 24V essentially drops the amps in half, so you can use small wire.
Lewis
Thanks! I hadn't considered the possibility of using a smaller gauge wire. Any other reasons to prefer 12V or 24V?
Lewis
There are advantages to both systems. Do you want 24 volt performance or lesser 12 volt. Do you want one battery or two. Is weight an issue. Why lug two batteries around if you don't need them. 12 volts can be used with one battery. 12 volts can also be used with two batteries in PARALLEL. (or three or four for that matter). It's all about weight, run time, and performance. Just like a car -- do you want a 4 cylinder econobox, a 400 HP cruiser, or truck.
Lewis
Thanks Silvertip! I wasn't as clear and specific as I should have been. I plan to have a two-battery setup in any event. My question is, since the trolling motor can be switched to run at either 12V or 24V, is there an advantage to hooking up the batteries in series vs. parallel in terms of power, battery life, etc.? I guess another way to ask is what do I gain (or give up) by running the motor at 12V with 2 batteries in parallel as opposed to running at 24V with 2 batteries in series?
Lewis
