12v relay on 12/24 trolling motor
Texas1
It’s time to replace the male and female connectors for my trolling motor it has a switch for 12 and 24 V however when I was taking it apart I remove the panel noticed that the relay only said 12 V
GA_Boater
The relay is only switching the 12 volts on from the second battery, not 24 volts from both batteries.
Normal setup.
Texas1
9BC6D2F8-72D0-485B-89C9-57BECFA818EA.jpeg892D4B8C-76D6-415B-B349-76A2DFAF921B.jpeg892D4B8C-76D6-415B-B349-76A2DFAF921B.jpeg
Normal setup.
Can I still use these 24v replacement parts on my 12/24v switchable motorguide?
Logic says yes cause the same amount of plugs/wires
wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
