I have an older Motor Guide 44lb thrust motor with 12V and 24V switches on the motor. There is also a run/charge switch at the front of the boat and another switch for Batt 1 and Batt 2 at the front of the boat. I have 2 sets of pos/negative wires (4) going to the rear of the boat to the batteries. The motor only runs when I switch on the 24 v switch on the motor, and I run it off of one battery. Can I run/should I run 2 batteries? Will it be faster with 2 batteries? How do I use the switches at the front of the boat-run/charge and Batt 1/Batt 2? Thanks for any help. Boat is 31 years old and still running good. Just want to use the electric motor the best that I can and never have been sure on what to do with the switches at the front or the batteries.
