125hp force 1984 prop help
carlosburitica
I recently got a 1984 bayliner 2110. It came with a 125hp force and need to replace the prop that is damaged. According to the seller this was the original prop that came with the boat.
This is what I can read on the prop
This is what the engine says.
And found this info.
According to that the model I have is a FPS529 but with a 16 pitch not with a 15 plus is for a smaller size boat. Been searching and don't find much info about the correct prop
Any help is aprecieted as well as where can I get a prop for it.
Thank you.
pnwboat
I think it may be difficult to find that exact same prop unless you have one modified by a propeller shop. Most of the props I've seen are 15, 17, 19, and 21 pitch. Looks like you might have a 21 foot hull? If so, I wouldn't go higher than a 17 pitch, but the real test is checking the WOT RPM's. It should be in the neighborhood of 5500 RPM's, but that depends on your personal preference and what the primary use of your boat is (skiing, fishing, cruising etc.).
jerryjerry05
Another pic of the whole prop?
​That # could be anything??
​Take it to almost any marine place and have them send it out for a rebuild.
​Make sure they know you want to know the size.
​They have a BUNCH of different "blocks" that they use to rebuild them in.
​Because of the size of your boat(21) it could be a special size(16p).because the 125 isn't the most powerful there is.
​But like pnwboat I haven't seen a 16 either??
Your motor's an 85 not an 84.
