125hp coil issue
galillo
i just bought a new coil CDI 182-4475r for my force 125hp 1988 c but is also not working I check the signal coming from the switch box and is fine, but when i connect the cable to the coil the signal is almos gonne i have not idea what is going on, any ideas.?
CharlieB
Re: 125hp coil issue
Swap coils with another cyl to see of the problem moves with the coil.
If this is the CDI/coil combo then you will need a DVA Meter to test the stator and trigger outputs to accurately diagnose your problem
