125 hp tilt trim ram leaking (1258x5a)
erosenwinkel
The "ram" that actually raises and lowers the motor leaks pretty badly, replaced the "o" rings, with obviously not the correct ones. Leaked after couple trips out. Anyone know what part number, where to buy, etc? Force 1258x5a
Eric
RRitt
Re: 125 hp tilt trim ram leaking (1258x5a)
1992-1994 has a proprietary top seal on a metric threaded tilt head. You are better off replacing.
1981-1992 is fully rebuildable. you can find seal kits on ebay.
1976-1981 uses a proprietary seal on the tilt and shock rams. you should be able to find replacement
caps for $10-$15. together with 1982-1992 seal kits you get full rebuild.
