FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hex drain plug is stripped pretty badly and I really don't want to mess with it.
Would it be ok to refill until clean gear oil drains from vent plug?
Thanks
You could take a pump and a little hose or tube and empty the foot which would certainly remove as much as a drain plug removal would, and then simple refill it until the oil does start coming out. Works for me...
Thanks guys. I'll try the tube next time . I just changed the impeller and after removing the prop, removed the bottom nut (behind prop) and got the gear oil to drain. No water.
