125 HP force L drive wire identification on harness
peacekeeper6
as everyone knows i am sure i had a bito a fire. i seperated all the wires from being fused together and was taking some readings and am getting very low resistance in the connector that goes to the front of the boat. only a few OHM open so i was wodnering if on the side that plugs into the engine side are some wires supposed to OHM together? with low resistance? i wanna rule out the connector beign melted beyond use so if i can reuse it i would like to thanx.
roscoe
Re: 125 HP force L drive wire identification on harness
The kill switch wires with the key off, but not with the key on, and anything touching the ground I suppose.<br /><br />Also, try checking for continuity.
peacekeeper6
yea the ground, i was checking for opens and closes, but i think two or 3 wires have continuity on them. it may be the kill switch
