125 hp 1988 bayliner trim tilt
Holtzlei
I have a 1988 bayliner with a 125 hp outboard i just had the valve unit on the trim tilt replaced it ran good for one trip around the lake then when i went to pull off the ramp the motor would not trim up it just clicked...it was able to be manually pulled up but after that it would not come down until the hydraulic line was bled we did the relay bypass test it makes a noise like its trying to raise but it does not raise.. Any ideas would be helpful thanks
jerryjerry05
The fluid full?
When you replaced it? did you make sure the end of the armature was installed in the slot right?
If it wasn't installed right it can grind the slot out and ruin the pump.
Holtzlei
I did not replace it a boat mechanic did though the guy is flaky... My dad got the motor to run but i am out of fluid so i have to pick some up and see if that helps thanks for the info
