125 force
rickmann
i just wired a 125 force on my bayhawk and the motor i bought is a 1990,i had to run all the wiring and buy a ignition switch for it,is there a wire that suppost to run back to the battery from the engine thats suppost to keep the battery charged
Frank Acampora
Re: 125 force
I hope you meant you had to run all the external wiring because my answer depends on that.
If you look at the engine wiring harness, you will see from the red terminal a wire goes down to the circuit breaker at the bottom of the terminal mounting plate. A red wire also runs from the bottom of the circuit breaker to the battery cable side of the starter solenoid. THIS is the wire that sends voltage back through the battery cable to charge the battery. When the engine is not running OR if you are using more amperage than the alternator can supply, this wire also supplies power from the battery to the ignition switch through the thick multi-colored multi-wired black cable.
This wire is only about 16 gauge so really, for any significant power needs you should access the battery directly with a fused supply line. This wire was really only meant to supply power for gauges.
The engine alternator only supplies about 7 amps so don't expect to run a stereo with a big amplifier and honking big speakers---'Aint gunna happen.
rickmann
Re: 125 force
since the motor has been sitting up,what precautions should i do before i try cranking it.i already drained the old gas,i just dont want it to lock up since its been sitting up
moparman
Re: 125 force
check the first of this forum for stickys about cranking a sleeping motor, it's under repair and maintenance,engine frequently asked questions, by all means do the water pump impeller,lower foot lube change and if you don't know when it was changed last, the fuel pump diaphragm ,hope this helps
john from md
Re: 125 force
First thing to do is buy a Clymer Force Outboard Shop Manual as you will need it to work on this engine.
John
