125 force
backdraft
Newbie, You should go to a 17 inch at the minimum. A 15 inch with a cup or double cup will be about perfect depending on the weight of your rig.. The 125's will burn a hole in the pistons if overpropped due to preignition [spark knock ] which you cannot hear due to the noise of the engine . Use mid grade gas. nvjb
roscoe
Re: 125 force
I was thinking 15" or even a 13"<br />They would give him 750 and 1100 more rpm respectively.
