125 force wont turn off with key
derekshep
my boat isnt turnig off with the key. i dont know why, i have the wires hooked up right in the switch, well thought so any way. does anyone have wiring diagram for a 1989 125 force. tired of choking the motor to kill it.
tater76
Re: 125 force wont turn off with key
Sounds like your key switch is either bad or wired incorretly. Did you recently change it or rewire for some reason?
Frank Acampora
At the switch, Blue wire to one "M" terminal, White wire to the other "M" terminal. At the engine terminal board, be certain to jump Blue wire to ground.
If you have a VOM or test light, test for continuity between the two "M" terminals with the switch off.
