125 force temperature Gauge
isis
I put a teleflex temperature gauge on my 1989 force outboard.Not doing some research i put a gauge that reads 130 degree to 240 degree(something like that).My question is should i put a psi gauge on it instead of temperature.The needle i barely moving and looking at some old Forum i guess the motor runs around 130 degrees.Also what would be consider hot temperature of the motor(150 degrees)?
Thank you
pnwboat
Re: 125 force temperature Gauge
I have a 125 Force that I put both temp and PSI gauge. Temp gauge is almost usless. My gauge starts out at 120 - 240 degrees. It barley moves. PSI gauge on the other hand is pretty active depending on engine speed. The PSI gauge gives you a better indication of water flow and reacts quicker to any problems.
