dknightfish
Thread starter- Joined
- Mar 17, 2013
- 7
I have a 1988 Force 125 that suddenly would not start. I took it out for the first time of the year few weeks ago, fished for two days no problem then all the sudden would not start; it cranks but does not kick. I first checked the compression to make sure I did not have a big problem; it was good, 110 PSI on all cylinders. I figured it was not getting spark, so I used a spark tester to check the ignition, and I found that only the top cylinder was getting spark, the bottom three cylinders have no spark.
What should I check next? The wires look ok, but how would I test them? How would I test the power pack or other common ignition components?
Thanks
Thanks
