120xr wont crank unless plugs are pulled
jaybirddog11
Re: 120xr wont crank unless plugs are pulled
Where is your ground cable currently mounted?
jaybirddog11
If it is not hooked up to the engine this could be your problem. When I bought mine, someone had it hooded up to the ground on the solenoid and I had similar problems to what you are experiencing. Also, if you have a deep cycle battery you should replace it with a marine starting battery.
Dsawyer16
yea its a marine battery...ill check out my grounds, thanks!
jaybirddog11
Sorry, it was not the solenoid but the starter relay mount they had it hooked up to. After I mounted it to the block, it fire right up.
thompy
sounds like the carbs have to be rechecked, float or needle seat not working, flooding it causing the motor to hydro lock, check out the fuel pump diaphrams again as well, after this stick your finger over the spark plug hole and have someone turn it over to get the gas to clear out of the cylinder, then oil the hole and do the finger thing again, reinstall plugs and fire away
milehighboater
Dsawyer, can you turn the motor over by hand with the plugs in? More or less can you turn it over with the emergency rope around your flywheel?
Jeremy90bay
I had a very similar problem with my 50HP force. I had to take the starter out and the bracket and clean in between the bracket and the block. Starters are self grounding so the bracket is the ground for the starter.
Dsawyer16
yes i can turn it over by hand with plugs in...no idea about an emegency rope, lol.
