120 mercruiser outdrive lower unit install
zwolfe15
Just had to replace the water impeller on my 120 mercruiser alpha one outdrive...now start the boat and when I shift it into forward or reverse the engine dies...guess I didn't get the shift switch back right???...anyone guide me through the steps to fix this..thanks!!
Re: 120 mercruiser outdrive lower unit install
Ayuh,.... Welcome Aboard,... Drop the lower again,... Make Sure Everything is in Forward,...
HOLD the lower in Forward, 'n reassemble....
(I use a bungee to hold tension on the propshaft)
The lower slipped outa gear as you were puttin' it together,.....
zwolfe15
Thanks for the info...could you tell me how to get the lower to go in forward to make sure I'm doing it right
Bt Doctur
drop the lower, turn splined shift shaft fully clockwise while turning prop counterclockwise.
zwolfe15
Thanks for you guys help...just got it back together and hooked it up to the water hose and everything works fine..gonna take it to the lake tomorrow
